Posts: 91 Joined: May 26 2009, 00:34
by cre » Sep 20 2009, 00:09
用proxomitron也有段时间了,初上手时候sidki太复杂不会用,终于自己写的垃圾规则cpu常100%郁闷的很,加上列表大量重复郁闷的很,就想试试sidki。
使用中确实很爽,直接就有base64解码等。可是不会用。只能发帖求教了。
比如地址
http://lcldlwz.lcldl.gov.cn/article/50/ ... 13186.html
<script language="javascript" src="/adfile/top.js">
在adpaths写
adfile*$TST(script=*) 可以是可以,写
/adfile/$TST(script=*) 就不行。带
/ 的该怎么写?
还有就是debug时match了,直接进
<script> Block: Scripts by URL 8.11.20 [pr] (d.2) 去test却没什么效果,不能这么玩么?
by cre » Sep 20 2009, 00:31
遇到_也纳闷。
<script type="text/javascript">
cpro_client='yoqoo_cpr';
cpro_cbd='#trans';
cpro_cbg='#trans';
cpro_ctitle='#0042FF';
cpro_cdesc='#909090';
cpro_curl='#008000';
cpro_clink='#ffffff';
cpro_flush=4;
cpro_w=120;
cpro_h=230;
cpro_template='text_noframe_120_240';
</script>
adkeys-j
cpro可以工作,cpro_就不工作了。
by cre » Sep 20 2009, 01:12
http://www.cuiweiju.com/configs/article/indextop1.js
//document.write('<center><iframe marginwidth=0 marginheight=0 frameborder=0 scrolling=no width=728 height=90 src="http://ad.cuiweiju.com/indextopgoogle.html"></iframe></center>');
//document.writeln("<div align='center'><iframe marginwidth=0 marginheight=0 frameborder=0 scrolling=no width=728 height=90 src='/temp/almama.html'></iframe></div>");
//document.writeln("<script type=\"text\/javascript\"><!--");
//document.writeln("google_ad_client = \"pub-0768862391114751\";");
//document.writeln("\/* 728x90, 创建于 08-1-10 *\/");
//document.writeln("google_ad_slot = \"5447603852\";");
//document.writeln("google_ad_width = 728;");
//document.writeln("google_ad_height = 90;");
//document.writeln("\/\/--> ");
//document.writeln("<\/script> ");
//document.writeln("<script type=\"text\/javascript\"");
//document.writeln("src=\"http:\/\/pagead2.googlesyndication.com\/pagead\/show_ads.js\"> ");
//document.writeln("<\/script>")
document.writeln("<script type=\'text\/javascript\'> ");
document.writeln("cpro_client=\'cuiweiju_cpr\';");
document.writeln("cpro_at=\'text_image\'; ");
document.writeln("cpro_161=4; ");
document.writeln("cpro_flush=4; ");
document.writeln("cpro_w=760; ");
document.writeln("cpro_h=90; ");
document.writeln("cpro_template=\'text_default_760_90\'; ");
document.writeln("cpro_cbd=\'#FFFFFF\'; ");
document.writeln("cpro_cbg=\'#FFFFFF\'; ");
document.writeln("cpro_ctitle=\'#0000ff\'; ");
document.writeln("cpro_cdesc=\'#444444\'; ");
document.writeln("cpro_curl=\'#008000\'; ");
document.writeln("cpro_cflush=\'#e10900\'; ");
document.writeln("cpro_uap=1;");
document.writeln("cpro_cad=1;");
document.writeln("<\/script>");
document.writeln("<script language=\'JavaScript\' type=\'text\/javascript\' src=data:text\/javascript,var%20prxCountAd%3D++prxCountAd%7C%7C1%3B for=nested ><\/script>")
//document.writeln("<center><iframe marginwidth=0 marginheight=0 frameborder=0 scrolling=no width=760 height=80 src=\"http:\/\/new.cuiweiju.com\/temp/smarttrade.html\"></iframe></center>");
这个该往哪里添加呢,用google_ad_*而不是indextop1?
Posts: 425 Joined: Jan 07 2008, 13:30
by ddbb » Sep 21 2009, 09:29
1.关于第一个 好像是因为Block: Scripts by URL这个规则里 在内容的前面有[/.=_-] 所以你再加了个/ 就匹配不到了 这个我不确认 他那个规则写得太复杂了.....
另外你TEST不行是因为他是有关联性的.......这个规则里用的变量是需要在其他规则里定义过他才能正常起作用的
2.这个你没给URL......
3.至于这个第3个...你是要把这个URL做掉么?? 打不开这个LINK???
关于删JS URL 我是自己写了一个规则做的.....
by cre » Sep 21 2009, 15:48
真的好复杂。。。
2的url无所谓的,也是<script> Block: Scripts by URL 8.11.20 [pr] (d.2)
cpro后有_,好像如你所说,在内容的前面有[/.=_-]......用cpro_*好像可以。
不是要做掉
我是想问哪条规则能在这个js内做掉那两片或者全部,替换js内容。
毕竟也是<script开头,/script>结尾的。如果尚未实现那修改哪条能实现呢。
Posts: 529 Joined: Dec 29 2007, 16:27
by phoenix » Sep 21 2009, 17:13
ddbb wrote: 1.关于第一个 好像是因为Block: Scripts by URL这个规则里 在内容的前面有[/.=_-] 所以你再加了个/ 就匹配不到了 这个我不确认 他那个规则写得太复杂了.....
AdPaths.ptxt 开头有提到:
# Blocked paths: entries in this list are single words like "ads". Each entry
# is matched against components in the path portion of the URL, separated by
# slash, dot, underscore, question mark, ampersand, semicolon, equal sign, or
# dash.
why wrote: 2的url无所谓的
不给url的话,别人怎么帮你测试?
第一块
// 开头的内容,会被
Protect: JS Comments II - Apply 规则保护起来,不会被过滤。
第二块内容,AdKeys-J.ptxt 中添加 cpro 可以将其过滤。
