关于5/24的所有......
Re: 关于5/24的所有......
:lol:
确实可以的........
这句厉害...........
可是没看懂语法.........恩........先死记下来吧.......... :?
Re: 关于5/24的所有......
sidki3003 wrote: Sidki 2009-05-24 Alpha 4:
  • Several changes to run smoothly on openSUSE, especially in Konqueror.
  • Several changes in the *.js files, to make them editable by Linux utf-8 editors.
  • Added 43unite's "Proxomitron via Wine on Linux" help file.
  • Numerous modifications, discussed elsewhere in this subforum over the past weeks.
  • Scattered code corrections, list entry removals/additions.
  • If you're using the config's general CSS for your own filters: I've renamed all classes/IDs starting with Prox/ProX/prox to Pr0x/Pr0X/pr0x, in order to avoid (intentional or accidental) collisions with page code.
http://sidki.proxfilter.net/prox-archiv ... -alpha.zip
Re: 关于5/24的所有......
使用 Sidki 2009-05-24 Alpha 4 规则包的朋友,如果 Log-Rare.log 中有记录,能否打包传上来?
我会提交给 sidki ,便于他改进规则。
Re: 关于5/24的所有......
我都忘了我用的是不是aplha 4 了
Reason: 为保护隐私,移除附件
Re: 关于5/24的所有......
(^(^</head>))只能被一个规则匹配吗?好像勾上多重匹配也不行?
Re: 关于5/24的所有......
Name = "Not Not Test 1"
URL = "www.baidu.com/"
Limit = 500
Match = "(^(^</title>))"
Replace = "What is$STOP()"
Name = "Not Not Test 2"
Limit = 500
Replace = " Proxomitron!$STOP()"
Re: 关于5/24的所有......
谢谢,测试了下应该是正常的。
Re: 关于5/24的所有......
Post by red »
ph,修改后的Remove/Hide: Ad Containers - Headers 09.06.27 [sd] (d.3 l.3),是否是ad这样的字符串不会被判定为广告
http://www.sangfor.com.cn/forum/read.php?tid=1742 依然被过滤
Re: 关于5/24的所有......
目前的检测逻辑是,如果 ad 前面没有字符,或者是这些字符 [%20-%40%5b-%60%7b-%7e] ,则判定为广告。你说的例子符合没有字符的情况。
你可以在 AdKeys-S 中将那个论坛帖子的 class 值保护起来。
Re: 关于5/24的所有......
Post by red »
谢ph,已经明白
# protect being hit by filter "Remove/Hide: Ad Containers - Headers"
www.sangfor.com.cn/forum/read.php?tid=1742 	  $SET(sAdKey=.f14.)$SET(sAdKeyR=<!--protect-->)
